Author [ES] [MY] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Z900 Clutch Problems  (Read 14355 times)
Offline BorderlandBiker
  • Retired, 77, knees are shot from surfing
  • Town / City: Royal Oaks
Re: Z900 Clutch Problems
Reply #30 on: July 10, 2021, 09:53:15 AM
*Originally Posted by coloradojohn [+]
I know this thread is a bit old but this exactly describes what my bike is doing. Its a hair over 9000 miles and has been doing exactly as he stated above. I'm very curious as to what is causing this and how I can fix it as it gets very annoying.
Did Kawasaki ever remedy this 'clutch' problem in their NEWER 2021 Z900 abs models?...Is this problem something I must look forward to fixing?...It sounds like an engineering or design problem that the company that would have fixed???
Reply #31 on: July 14, 2021, 10:48:52 AM
This is an old thread and most of the bikes affected seem to be 2017 models.
Kawasaki must have been aware of it and shuffled the friction plates for 2018 onwards. I assume that fixed it?
Some (myself included) have fitted heavier clutch springs as insurance.
My 2020 (stock) with 24.000+km never had clutch slippage. 3mm clutch cable free play from day one.
Tried to provoke slippage, WOT in 6th gear from 3500rpm until cca 9000rpm every now and then, and nothing, just linear acceleration.
Reply #32 on: July 14, 2021, 10:56:52 AM
.......3mm clutch cable free play from day one.....
 This. ^ 👍
Offline Zed62
  • Quiet Pipes Enrich Lives
  • Town / City: Rosedale
Reply #33 on: July 21, 2021, 02:50:11 PM
  Coming from the Z400 I am familiar with the clutch problem discussion.  Here is the pattern I have seen:  Improperly adjusted cable free play due to lack of maintenance or mechanical skill and abuse of the motorcycle ie. doing burnouts & etc.
  A basic knowledge of how a motorcycle wet clutch works is a huge asset; if you do not know what you are doing you should get someone to do the adjustment for you.
  The Z400 had 5000 kms on it when I traded it and the clutch was never a problem.  I am certain that the Z900 has a totally adequate clutch; although I will be adding a clutch cable return spring as I did to the Z400.  Not sure why some feel that the clutch should begin to disengage at the slightest pull of the lever. :084:
Last Edit: July 21, 2021, 02:50:51 PM by Zed62
ZED62
Yamaha HSI, RD400, RD350 LC, Honda CX500, Seca650, Z400, Z900
Offline PJ69
  • Government funded = tax payer funded
  • Town / City: Rushden
Reply #34 on: July 28, 2021, 09:14:36 AM
I had a slipping clutch many moons ago on my F2 zx6 ginger Ninja. When Corby Kawasaki looked at it, they said the combined depth of the numerous friction and other plates was out of tolerance. Apparently, the steel plates vary slightly in thickness from batch to batch, and can result in a difference, plus wearing friction plates add to the issue.
More play in the cable is better than not enough as the actuator wears and overheats.
The government cannot give anything to a person it has not first taken from someone else.
Offline Rr1982
  • Town / City: Newport
Reply #35 on: September 14, 2021, 08:29:16 PM
Yeah I've got 8100 on my bike started slipping at about 5,000 RPM with a full throttle I tried adjusting the cable and I have adjusted it throughout since new and although it helps somewhat to loosen it up more slack that is it's still slips. Does anybody know of the 2018 clutch pack can be used in my 2017 and did the 2018 have any clutch issues?
Reply #36 on: September 14, 2021, 09:11:38 PM
*Originally Posted by Rr1982 [+]
 Clutch for all years seem to be the same except for the friction plates,
 Friction plates for '17 & '18 are the same. Revised for 2019 onwards
 '17 & '18 have 7-off 130880588 and 2-off 130880568
 '19 onwards have 9-off 130880568
 130889588 is shown as superseded by 130880568 so you SHOULD be presented with ....568's anyway.
Offline Rr1982
Reply #37 on: September 14, 2021, 10:33:17 PM
According to the Kawasaki Parts Diagram the 2018 has 9 of the same friction plates, so maybe the change occurred in 2018.
Last Edit: September 14, 2021, 10:35:24 PM by Rr1982
Reply #38 on: September 14, 2021, 11:05:55 PM
 Maybe. Could have changed during the year but irrelevant unless you are considering using second hand parts (surely not).
 You need 9x 13088-0568.  :028:
Offline Rr1982
Reply #39 on: September 14, 2021, 11:44:43 PM
Anyways I'm just wondering if the change was due to them knowing about clutch slipping issues.
