Author Air filter  (Read 4143 times)
  • Offline Den   ca
    • Z900 Pro  ‐    109
    Offline Den
    Air filter
    on: Aug 09, 2017, 05.05 pm
    Thought I would check out my air filter, peeled everything down to tank, then got a little stumped..anyone taken the tank off?
    A vid or anything?
    Thanks!
  • Offline StreetHawk   us
    • Z900 Pro  ‐    132
    Offline StreetHawk
    • Town / City: Brandon
    Re: Air filter
    Reply #1 on: Aug 09, 2017, 05.11 pm
    Not yet but curious. I started to but then was like ### it. LOL
  • Offline Den   ca
    • Z900 Pro  ‐    109
    Offline Den
    Re: Air filter
    Reply #2 on: Aug 09, 2017, 07.01 pm
  • Offline lincolns mullet   us
    • Z900 Member  ‐    56
    • Town / City: Texas
    Re: Air filter
    Reply #3 on: Aug 10, 2017, 04.43 pm
    Shouldn't be too much trouble.  I plan on it tonight, need to install the Rapid bike module.
  • Offline smokkan   se
    • Z900 Pro  ‐    146
    Offline smokkan
    • Country: se
    Re: Air filter
    Reply #4 on: Aug 10, 2017, 06.00 pm
    If you have help from a friend that can hold the tank back it's easy. Then you dont need to remove the fuel lines.
    • Z900 Member  ‐    56
    Re: Air filter
    Reply #5 on: Aug 10, 2017, 06.16 pm
    I was thinking of going that route or using a ratchet strap to hold it up since I have eye bolts in the garage ceiling.
    • Z900 Pro  ‐    146
    Offline smokkan
    • Country: se
    Re: Air filter
    Reply #6 on: Aug 10, 2017, 06.23 pm
    *Originally Posted by lincolns mullet [+]
    That will work great. Remove all fairings, it's hard to run the wires from the storage area when the side fairings are on. The air box can be little tricky to remove.
    Installing the module should take 40-60 min.
    Don't forget to check this thread out: https://www.z900forum.com/index.php?topic=230.new;topicseen#new
    • Z900 God  ‐    4759
    Re: Air filter
    Reply #7 on: Aug 13, 2017, 04.23 pm
    It helps a bunch if there's just a little gas in the tank. Either run it down or pump it out.
    I only removed one tank from a FI bike so I don't know if all the fittings are the same. But the one I did has clips you have to depress to remove the hose. If it is the same, (most likely) be careful to hold the clip fully pressed when removing or replacing the hose or you'll damage the o-ring (like I did).
  • Offline ras   us
    • Z900 God  ‐    4384
    Offline ras
    • Bike: 2021 Versys 10000
    Re: Air filter
    Reply #8 on: Aug 13, 2017, 09.55 pm
    and this one time at band camp  :164: :164:
    whoops  :431: :455:
    make sure the clips are snapped in solid when putting it back together as well. I had one come apart on me while on a ride blowing gas every where, it had stayed together for 100 miles are so before it blew apart.
