Author [ES] [MY] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Spotlight mounting. How to?  (Read 819 times)
on: November 03, 2021, 02:25:51 AM
Hi Guys and Gals,
I have a set of spotlights and I also have a light bar. The electrics (for me) is easy but the physical mounting is the problem I have so looking for ideas of mounting a pair of spots and / or a light bar. I was thinking of mounting the light bar under the headlight with brackets running from the fork clamp bolts. Spot light I don't know where to mount.
These are the pair of spot lights I have
Last Edit: November 03, 2021, 02:28:35 AM by MaverickAus
Re: Spotlight mounting. How to?
Reply #1 on: November 03, 2021, 06:33:05 AM
First observation with the light bar is to watch out for fender clearance on full fork compression.
 Fork clamps perhaps? Something like these?
 https://www.ebay.co.uk/itm/CNC-Motorcycle-Fork-Mount-Bracket-Clamp-Holder-For-Spot-Fog-Driving-Head-Light-/164800924549?mkcid=16&mkevt=1&_trksid=p2349624.m46890.l49286&mkrid=710-127635-2958-0
 You could probably find tidier options available if you look harder than I did.
 I seem to recall someone using longer bolts with tube spacers in place of the front fender mountings bolts but I can't remember who or when.
Reply #2 on: November 03, 2021, 07:30:59 AM
Yes I had thought about that and was going to check it out
Bit on the ugly side I'll have a look and search for others
I have seen that before somewhere again thanks for the suggestions
Reply #3 on: November 03, 2021, 08:08:52 AM
Had a search on ebay and come up with these
https://www.ebay.com.au/itm/183547107653
I like this one because it small and neat however my lights are quite heavy and I feel no matter how tight you make the mounting bolt with road vibration the mounts may rotate and therefore the lights will be uselessly pointing at the ground
https://www.ebay.com.au/itm/174540927300
https://www.ebay.com.au/itm/174843230796
Reply #4 on: November 07, 2021, 06:15:04 PM
So I'm gathering from the lack of answers no-one has ever fitted spot lights to a Z900?
Offline mADmAN
  • Town / City: Petaling Jaya
  • Country: my
Reply #5 on: November 12, 2021, 03:54:51 AM
*Originally Posted by MaverickAus [+]
I did on my 17 z9
But i have crash bars so i mounted on them directly which is what i believe most ppl do.
Ive seen others use the fork clamp on their bikes (not z9) n works well enough for them...
Looks wise is errmm.... Debatable hahahaha
Maybe u could fabricate a mounting bar for the spotlights....where the bar is bolted onto the same mount for the horn..
Reply #6 on: November 12, 2021, 09:07:11 AM
*Originally Posted by mADmAN [+]
I did on my 17 z9
Thanks for the response I'm doing a dusk to dawn ride in a couple of months, the stock lights are no-where good enough for country riding at night, so I really don't give a damn about the looks. In fact I will be able to remove them by undoing 2 bolts and unplugging 2 leads if I choose to.
I'll have a look at the horn mount.
Last Edit: November 12, 2021, 09:08:32 AM by MaverickAus
Offline Swamp
Reply #7 on: November 18, 2021, 01:03:28 AM
Get a set of these, they work great , give the bike a more 'solid' look and can fit lights to them
