Author Topic: 2020 Stock Setting from the Owners Manual  (Read 337 times)
  • Offline Mach 5   us
    • Z900 Junior Member  ‐    7
    Offline Mach 5
    • Town / City: North Ridgeville
    on: Sep 21, 2022, 01.51 pm
    Hello,
    I am picking up a 2020 Z900 in a few days.  Unfortunately, it doesn't have the owner's manual.
    Can someone point me to the 2020 stock suspension settings and steps from the manual?
    I'm sure I'll make changes but need a starting point.
    2020 Kawasaki Z900
    2015 BMW R1200R
    2010 Kawasaki Nomad 1700 (for her)
  • Offline 3alfa3   hr
    • Z900 Master  ‐    602
    Last Edit: Sep 21, 2022, 02.15 pm by 3alfa3
  • Offline Mach 5   us
    Offline Mach 5
    2020 Kawasaki Z900
    2015 BMW R1200R
  • Offline Mach 5   us
    Offline Mach 5
    Re: 2020 Stock Setting from the Owners Manual
    Reply #3 on: Sep 21, 2022, 02.43 pm
    Also,
    What size is the nut for front preload?
    Do I need a spanner wrench for rear preload, or is it something else?
    2020 Kawasaki Z900
    2015 BMW R1200R
  • Offline 3alfa3   hr
    • Z900 Master  ‐    602
    Reply #4 on: Sep 21, 2022, 03.20 pm
    *Originally Posted by Mach 5 [+]
    Also,
    14mm
    Spanner is difficult to use because of frame (not enough space for spanner to turn). I used hammer and flat screwdriver to adjust rear shock preload. To be precise, i used that only for locknut: after it was loosened,i rotated spring with my hand and adjustment nut followed spring. Hammer and screwdriver again to tighten lock nut.
    Last Edit: Sep 21, 2022, 03.21 pm by 3alfa3
  • Offline Mach 5   us
    Offline Mach 5
    Reply #5 on: Sep 21, 2022, 03.38 pm
    Great.  Thanks again1
    2020 Kawasaki Z900
    2015 BMW R1200R
  • Offline Bentham   gb
    • Z900 Pro  ‐    118
    Offline Bentham
    • Town / City: Bristol
    Reply #6 on: Sep 22, 2022, 05.49 pm
    Hi,
    The rear preload needs a C spanner, the toolkit under the seat should have one if not they are easily available.
    If you remove the trim over the RHS frame then the collar is more accessible, although it will still only move a little at a time.
    Hope this helps,
