Author Removing controls on handlebar  (Read 929 times)
  • Offline ibnsneju   us
    • Z900 Member  ‐    27
    Offline ibnsneju
    • Town / City: Altanta
    on: Sep 25, 2022, 06.09 am
    Hey guys, anyone know a good resource to find some sort of manual to remove/install the switch controls (for handlebar replacement) ? been looking everywhere on google and cant find anything, possibly googling the wrong thing (maybe it isn't a Z900 specific endeavor)
  • Offline MaverickAus   au
    • Z900 Pro  ‐    485
    Re: Removing controls on handlebar
    Reply #1 on: Sep 25, 2022, 10.11 am
    Undo the 2 JIS screws, they will fall off
    • Z900 Member  ‐    27
    Offline ibnsneju
    Reply #2 on: Sep 25, 2022, 03.47 pm
    *Originally Posted by MaverickAus [+]
    And just slide the throttle and clutch grip off after removing my bar end mirrors?
    • Z900 God  ‐    2925
    Reply #3 on: Sep 25, 2022, 08.53 pm
    *Originally Posted by ibnsneju [+]
    Clutch side switch clamshell:
     Just undo the two screws and open it up. There is nothing to fall out and lose on the floor. Easy.
     Throttle side:
     Remove lever assemblies and RH bar end.
     Partially open up the clamshell by slackening off the two clamp screws but do not split it completely open. Just enough so that it loose on the handlebar.
     Unbolt the handle bar clamp and slide the handle bar towards the clutch slide and out of the throttle tube.
     Doing it this way will leave the throttle tube and throttle cable undisturbed and none of the cables or wires will get stretched.
     However if you are replacing the handlebar with something undrilled you will have to split open the throttle tube which is a little daunting for the first time. Just take your time and perhaps take some photos to help you understand the throttle cable routing. Its pretty straightforward.
      :028:
    • Z900 Member  ‐    27
    • #4
    Offline ibnsneju
    Reply #4 on: Sep 26, 2022, 12.04 am
     Throttle side:
      :028:
    Thanks a lot for this. What exactly is supposed to be drilled? I'm getting the clip-ons with the fork adapter plate from aliexpress. I'm also assuming I don't need to remove the grip from the throttle tube, correct?
    this is my first DIY mod and since this deals with the brain of my bike I don't wanna screw it up
  • Offline KellyL   au
    • Z900 Pro  ‐    256
    Offline KellyL
    Reply #5 on: Sep 26, 2022, 12.12 am
    The switchblock has a pin that goes into an index hole in the handlebar. It prevents the block from twisting.
    Some people grind off the pin on the switchblock, but I prefer drilling a hole in the new handlebar as it's safer. It's quite easy to do with a vice and the right drill bit. Just measure thrice and drill once.
    • Z900 God  ‐    2925
    Reply #6 on: Sep 26, 2022, 12.37 am
     Yeah you can leave the grip on the throttle tube.
     The rest of it is as Kelly said though I drilled the bars in situ on the bike. Centre punch and drill a small pilot and work up from there  I found that 4mm with a generous chamfer was big enough to locate the pin. It's worth doing much better than grinding the pin. Yuck
    • Z900 Member  ‐    27
    • #7
    Offline ibnsneju
    Reply #7 on: Sep 26, 2022, 01.38 am
    Is this the hole you guys are talking about on the bars?
    • Z900 God  ‐    2925
    Reply #8 on: Sep 26, 2022, 06.44 am
    Yes.
    • Z900 Member  ‐    27
    • #9
    Offline ibnsneju
    Reply #9 on: Sep 26, 2022, 04.15 pm
    Sweeet, hopefully this is an easy install then  :763:
