Author Suddenly won't start  (Read 8374 times)
    • Z900 God  ‐    4714
      #10
    Re: Suddenly won't start
    Reply #10 on: Jan 01, 2023, 12.39 pm
    Did you check the condition of the plugs? Wet?
    Oh, I see in your original post you said they were firing. So I assume they looked dry and tan.
    We’re any modifications made to the bike?
    Last Edit: Jan 01, 2023, 12.42 pm by zed9
  • Offline Degorath   us
    • Z900 Junior Member  ‐    3
      #11
    Offline Degorath
    • Town / City: Bauxite
    Reply #11 on: Jan 02, 2023, 01.57 am
    I'm having the same exact issue. Rode for about an hour, took a break and filled up, rode about 30 minutes to see some people and when I tried to leave 2 hours later crank/no start.
    Read about starting it as soon as the ignition is switched on to bypass diagnostics. Tried it, and it worked!.....for like 5 seconds.
    Bike dies as soon as diagnostics finish/ fuel pump stops (don't know if this is coincidence).
    Exhaust smells very rich.
    No mods other than Ixil slip on and no known previous issues
      #12
    Offline Degorath
    Reply #12 on: Jan 02, 2023, 03.25 pm
    *Originally Posted by Smoky [+]
    Not kickstand...motor spins.
    Have you checked your vehicle down sensor?
  • Offline Smoky   us
    • Z900 Member  ‐    74
    • #13
    Offline Smoky
    • Town / City: E. Tenn
    Reply #13 on: Jan 03, 2023, 01.24 am
    Starting fluid a no go...there are 2 sets of butterflies in the throttle bodies and they don't and won't both open during the start up sequence. I squirted a shitload in but i don't think it's making it into the combustion chamber. Double checked all 4 plugs for fire. They all have strong spark... anybody?
  • Offline Led Zed 70   us
    • Z900 God  ‐    1003
      #14
    Reply #14 on: Jan 03, 2023, 02.05 am
    Just for the hell of it try starting with gas cap open. Maybe clogged vent? Probably not but hell don’t hurt to try. Full injectors, clogged fuel line? You said fuel pump and relay is working?
    Last Edit: Jan 03, 2023, 02.27 am by Led Zed 70
  • Offline Smoky   us
    • Z900 Member  ‐    74
    • #15
    Offline Smoky
    Reply #15 on: Jan 03, 2023, 11.28 am
    Vehicle down sensor won't allow fuel pump or ignition spark. Not that. Not fuel pump or filter. Plugs are properly gapped and firing. Back to timing or injectors.
    • Z900 God  ‐    4714
      #16
    Reply #16 on: Jan 03, 2023, 03.06 pm
    What about the throttle plate position sensor?
    • Z900 God  ‐    1003
      #17
    Reply #17 on: Jan 03, 2023, 03.48 pm
    Fuel pressure regulator? When you say battery is “hot” does it actually read high 12-13 Volts sitting ideal not running or cranking?
  • Offline Zaniac948   us
    • Z900 Member  ‐    30
      #18
    Offline Zaniac948
    Reply #18 on: Jan 03, 2023, 06.01 pm
    Has the bike displayed an error code?
  • Offline Smoky   us
    • Z900 Member  ‐    74
    • #19
    Offline Smoky
    Reply #19 on: Jan 03, 2023, 08.11 pm
    No error code because it doesn't run. Battery kept on trickle charger 12.5 volts or above. Fuel pump is priming during the 3 second cycle fuel pump wont run continually until engine starts after priming. All 8 butterflies operate normally ( both pri, and sec.) When primaries open secondaries close and visa versa until they both open upon engine run condition
    Last Edit: Jan 03, 2023, 08.16 pm by Smoky
