On the exhaust gaskets, you can reuse them ,(I have several times) just take a flame (propane butane ext..) get them glowing red and immediately throw them in cold water. It Re aneals ( expands them) ready for Reuse.
Just gave it a go on oem gaskets. Gave one 90 sec with map/pro benrzomatic torch hanging from a coat-hanger wire, it was hard to get a uniform red, then straight into cold water. Thickeness measured 2.10 mm before and 2.10mm after, none of the header pipe high/low indentations changed on the gasket.
I just buy 3 sets of K factory gaskets from webike any time I put an order in if needed. I did try to reuse the OEM once (without the above) and had to chase down a ticking noise that ended up being the flange gasket. Each one to there own. Maybe might work with an oxy but not for me.
Z900 not listed but just used a set on the z900 motor, same/same.
https://japan.webike.net/products/24983285.html
