Author Throttle Problem.  (Read 305 times)
  • Offline Sethyrz   dk
    • Z900 Junior Member  ‐    7
    Offline Sethyrz
    • Country: dk
    Throttle Problem.
    on: Sep 17, 2023, 06.56 pm
    Hello Z900 ppl! :-)
    After I changed the clutch lever and brake (I had to peel off the turn signal module to change the clutch lever) my motorcycle started running unevenly in the engine as if it was stuttering when you give it gas and hold it. I drive with a slip on exhaust.
    I could see in the Display TFT it had reset because of the clock was changed.
    2022 model. 2300km.
    Its mostly when I drive around in the city.
    I had another slip-on on before I did change the clutch lever and then It did run without any problems.
    • Z900 God  ‐    3130
    Re: Throttle Problem.
    Reply #1 on: Sep 18, 2023, 07.32 am
    *Originally Posted by Sethyrz [+]
    Hello Z900 ppl! :-)
    2022 model. 2300km.
    Sounds like the clutch switch maybe playing up.
    You may have damaged or mislodged something installing the new lever.
    Or it may be a design fault with the new lever.
    Try re installing the old lever.
    Did you swap the bronze bushing into the new lever,?
    Offline Sethyrz
    • Country: dk
    Reply #2 on: Sep 18, 2023, 07.34 am
    I think its the clutch switch since It Broke off after the installing so I have to check If I Can find a new one or glue it back together :-p
    • Z900 Master  ‐    802
    Reply #3 on: Sep 18, 2023, 07.57 am
    Buy new one and be careful in the Future - that pin is very brittle.
    In the meantime, disconnect cable from clutch switch, this will eliminate jerkiness when riding.
    • #4
    Offline Sethyrz
    • Country: dk
    Reply #4 on: Sep 18, 2023, 08.08 am
    Thanks man I will :-)
  • Offline notsoaverageguy   us
    • Z900 Junior Member  ‐    8
    • Bike: Z900rs cafe
    • Town / City: SanDiego
    Reply #5 on: Yesterday at 10:26 pm
    Assuming it’s the same on the z as the Rs I print those pieces and if you send me your address I will send it to you. Broke mine to so had to draw it up and print it so I made a few extra.
