Author Whining noise from front sprocket  (Read 2087 times)
0 Members and 3 Guests are viewing this topic.
  • Offline Dream   my
    • Z900 Member  ‐    60
    Offline Dream
    • Town / City: Borneo
    • Country: my
    on: Dec 08, 2023, 10.52 am
    I just cleaned and lube the chain for the third time and all of a sudden I get this whining noise that from my ear comes from the front sprocket. I relube the chain and the noise still persists. The noise seems to be speed related rather than gear. It starts to whine above 55km/h. And also once I let off the throttle the whine goes away. I've checked the slack and it is still within spec. Bike is at 3000kms now. Any idea?
    Last Edit: Dec 08, 2023, 10.54 am by Dream
    • Z900 God  ‐    3218
    Re: Whining noise from front sprocket
    Reply #1 on: Dec 08, 2023, 12.40 pm
    Get the bike up on a rear stand and spin the back wheel.
    Does the chain runs centrally on the rear sprocket?
    If its hard up against ine side nd you manually recente it does it move over back to that side as soon as you spin the wheel?
    Also check the chain runs smoothly, no tight spots.
    Last Edit: Dec 08, 2023, 12.41 pm by Cazzy_R
  • Offline Dream   my
    • Z900 Member  ‐    60
    Offline Dream
    • Country: my
    Reply #2 on: Dec 08, 2023, 01.55 pm
    Thanks Cazzy_R, I'll check that tomorrow. What puzzled me was that the whine wasn't there before I clean and relube the chain.
    • Z900 God  ‐    3218
    Reply #3 on: Dec 08, 2023, 02.29 pm
    *Originally Posted by Dream [+]
    Yeah valid. Same lube & cleaner as usual?
  • Offline Dream   my
    • Z900 Member  ‐    60
    • #4
    Offline Dream
    • Country: my
    Reply #4 on: Dec 08, 2023, 10.13 pm
    Yeah, same lube & cleaner.
  • Offline Dream   my
    • Z900 Member  ‐    60
    Offline Dream
    • Country: my
    Reply #5 on: Dec 09, 2023, 05.19 am
    I checked, the chain is not running centrally to the rear sprocket and is against the inner side. I manually recenter it and it will slide back to the inner side as soon as I spin the wheel. I can hear a click when I manually recenter the chain. I checked the chain marks on both side and is at the same mark, I know the markings can be inaccurate due to manufacturing tolerances. Is this normal?
    • Z900 God  ‐    3218
    Reply #6 on: Dec 09, 2023, 09.55 am
     When I had chain whine that was the cause.
     During a readjustment I matched the marks either side when previously the were slightly "off". Prior to that the chain ran silently.
     So I decided to ignore the marks and reset the wheel so that the chain was central on the sprocket. i.e. After a few spins of the wheel I  could push the chain over either left or right to get the "click".
     Silent running returned.
     I did try one of those motion pro type alignment tools which clamp to the rear sprocket but I honestly could not see any difference between the matched and mismatched settings but the difference to my ears was very obvious.
    • Z900 Master  ‐    873
    Reply #7 on: Dec 09, 2023, 10.16 am
    1. this will be long post and my English is not good so keep that in mind, i hope it will be understandable to anyone
    So,
    Wheels should be aligned for Z900, if bike is not dmaged in accident, chain should be aligned when wheels are aligned. I did wheels alignment before first ride, it needed it, there was discrepancy. Now at 72500km (third chain and sprockets on the bike) and never had wheels/chain aligmnent issue - i just count flats on the adjusters for chain adjustments/replacements.
    Markings on swingarm are not perfect, i do not use them at all, but, in my case, 1mm difference is present: left (chain) side is more to the back on markings and wheels and chain are perfectly aligned. I do take (once per Year) wheel alignment checks and it's always fine.
    When wheels are aligned (and chain should be also), best practice in my opinion is to mark one flat of the chain adjuster with paint for future adjustment (its easy, just count how many turns you move each adjuster - one flat is 1/6 of a turn so its precise more than enough and you should never check alignment again - just count the turns and do it for both left and right side the same and do it slowly so you dont lose count.
    Chain should be centered between front and rear sprocket, but, there is a tolerance: if chain does not touch rear sprocket sideways as you carefuly rotate rear wheel, it doesnt matter if it sits more on one side or the other. But, if its hard against one side, there is a problem and should be fixed emediatly.
    From picture above, i would say that wheel shoud be adjusted: if chain tension is OK, right (brake) side should be adjusted to bring rear wheel more to the front.
    But do rotate the wheel several times in different positions because rear sprocket could be slightly offset.
    Once you get that inner plates on both sides of the chain are not hard against the rear sprocket (left or right), thats good enough. Only, if sprocket is bent, or not instaled correctly, that could influence the "reading": there is a tolarance for that - spin the wheel and see if rear sprocket follows "number 8". Better yet, measure it when slowly rotating the wheel: tolerance is 0.5mm.
    P.S. I would take front sprocket cover off and check if front sprocket nut is loose - usualy that nut is torqued much more than needed on Kawasakies, but, wont hurt to check (and clean cover and surrounding areas from old lube)
    Hope it helps
    Last Edit: Dec 09, 2023, 11.11 am by 3alfa3
    • Z900 God  ‐    3218
    Reply #8 on: Dec 09, 2023, 10.38 am
     :0461:
  • Offline Dream   my
    • Z900 Member  ‐    60
    • #9
    Offline Dream
    • Country: my
    Reply #9 on: Dec 09, 2023, 03.03 pm
    Thanks a lot for the inputs Cazzy_R and 3alfa3. The chain tension is well within spec still. Once my toque wrench arrives, I'll try to adjust the right side (brake side) of the adjuster to bring the wheel forward a little and report back.
