Author [ES] [MY] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: 117 kg settings  (Read 1744 times)
Online zeta
  • Town / City: Lohja
  • Country: fi
117 kg settings
on: December 28, 2018, 04:41:43 PM
Weight with the gear some 117 kg.
Rear: 10 turns in, free sag 7 mm, rider sag 38 mm ( the first measurement was 33 mm, but it changed for some reason, multiple measurements), this is a compromise to still have some free sag.
Front: all in, free 22 mm, rider 44 mm, there is nothing that can be done with the oem suspension.
I'll revisit this later when I have been able to ride the bike, that means 2.5 months at least.
Offline Scim77
  • Town / City: Pulborough
Re: 117 kg settings
Reply #1 on: December 28, 2018, 06:20:19 PM
Surely you can increase the front pre-load slightly and tweak the rebound as required? Even the stock front suspension has adjusters to alter both of these.
Who in their right mind would design a vehicle that falls over when it stops?
Online zeta
  • Country: fi
Re: 117 kg settings
Reply #2 on: December 28, 2018, 07:14:01 PM
*Originally Posted by Scim77 [+]
No, the front is 'all in' as I said, the pre-load and rebound are both at the max setting. It is what it is. The only way to adjust the front end is to lose weight (that is not a bad idea...).
Offline JohnCW
  • Town / City: Sydney
Re: 117 kg settings
Reply #3 on: December 28, 2018, 10:41:38 PM
*Originally Posted by zeta [+]
Expect the sag measurement to be different every-time you measure it, that's normal, and caused by 'stiction' (static friction).  That's why the 'Race Tech' method of taking the average of two measurements (one allowing the bike to fall to rest, and the other from rising to rest) is a much more accurate method.
The difference between the two measurements is the amount of stiction in the suspension, and a number with knowing.
Offline Scim77
Re: 117 kg settings
Reply #4 on: December 29, 2018, 09:32:57 AM
Hmm. Sorry 'zeta'.  I understand. As you say, its either lose weight or fit stronger springs. You are roughly twice my weight!  If it is some incentive towards your weight loss, I can confirm that my bike accelerates like stink with just me onboard!  :038:
Online zeta
  • Country: fi
Re: 117 kg settings
Reply #5 on: December 29, 2018, 09:48:00 AM
Indeed, the best tune-up for the bike is to shed some 20 kg of lard off the rider  :008:
Offline George26
  • Bike: Z 900
  • Town / City: Odense
  • Country: dk
Re: 117 kg settings
Reply #6 on: January 04, 2019, 04:53:17 PM
Almoust the same here I weight 100 kg. with gear on, Reat 7 turns in free sag 6, rider sag 37. Front 2 turns to full in, free sag 18, rider sag 37 and it works perfekt for me. In April I am going to bring her to the track (Slovakiaring) see how it going to respond there.
Offline bmartinZ900
  • Town / City: Denver CO
Re: 117 kg settings
Reply #7 on: January 05, 2019, 06:49:43 PM
Can most assuredly confirm! I was 265lbs in April when I bought the bike. Rode around all summer like a fat kid on a Mongoose. Finally decided it was time to change myself rather than the bike. Lost 40lbs since September and now at 226lbs the bike is much more enjoyable to ride. Should be down around 200lbs by the time riding season starts and excited to feel the bike then.
Offline George26
  • Bike: Z 900
  • Country: dk
Re: 117 kg settings
Reply #8 on: January 10, 2019, 01:08:53 PM
 :0461: I just started to loose some bacon, now I am 100 kg. when the season start I want to be under 90 kg. so I can enjoy the bike more
Last Edit: January 10, 2019, 01:10:46 PM by George26
Re: 117 kg settings
Reply #9 on: January 25, 2019, 02:07:46 PM
*Originally Posted by bmartinZ900 [+]
Good on you  :047:. You feel better off the bike as well. Win, win.
