Author Topic: Spring rates  (Read 3692 times)
  • Offline TwiggLe   us
    • Z900 Member  ‐    32
      #10
    Offline TwiggLe
    • Bike: '21 Z900
    • Town / City: Akron, Ohio
    Re: Spring rates
    Reply #10 on: Jun 22, 2022, 12.23 pm
    Zed9 thoughtfully shared that his rear shock was re-sprung with a 700lb/in (120N/mm) for his riding weight of 200lb (90kg). Fork springs at .95N/mm
     I'm 250lbs (115kg) in gear and I wonder what spring rates would be correct for my weight?
     Are there any rider weight charts/tables for the Z900 out there?
    What specific parts did you end up going with?
    I'm just over 250 fully geared and was looking at the k-tech R lite rear (Part#:287SD-017-150-092), and then trying to find replacement springs to install on the front but wasn't sure what ones to get.
    Had a shop adjust my stock suspension last year but I think they just maxed the preload now I feel like I'm going to be launched off the bike on any decent bump.
    • Z900 God  ‐    2889
    • #11
    Re: Spring rates
    Reply #11 on: Jun 22, 2022, 02.21 pm
    *Originally Posted by TwiggLe [+]
     K-Tech didn't offer rider weight specific versions when I ordered my K-tech Razor-R.
     I gave my suspension supplier my rider weight and my Razor-R arrived with a 110N/mm spring (2 sizes stiffer than default).
     For whatever reason K-tech suggest a 120N/mm spring for the Razor-Lite and a 130N/mm spring for the Razor-R, at our weight, so I'm a little suspicious of their numbers. The 110N/mm spring works well for me but I think a 120 would be better still. The part number you quoted comes with a 120 spring so I think you will be good there.
     I went a different way on the front with a Maxton single leg cartridge which leaves the standard "spring only" unchanged. The Maxton leg has 1.05N/mm spring rate, According to K-tech the remaining "spring only" leg has a .85N/mm spring. So that averages out at 0.95N/mm. The Maxton cartridge is wonderful no complaints what so ever but last I heard not available on your side of the pond.
     I'm not sure upping the spring rate alone, up front will help much without some attention to the damping.
     Hope that helps.
    Last Edit: Jun 22, 2022, 02.22 pm by Cazzy_R
    • Z900 God  ‐    4568
      #12
    Re: Spring rates
    Reply #12 on: Jun 22, 2022, 04.12 pm
     Hope that helps.
    If you have averaged a .95 at 250 pounds you have improved the situation but I think you’re still falling short.
    I have a .95 rate and I’m a meager 205 lb fully geared. And at .95 I’m using nearly all my front travel according to my zip-tie while street riding (which is what you want). If I were a track rider my guy would have installed 1.0 springs.
    It’s one or the other. If you want stiffer springs for the track then you’ll have a harsher ride on the street and won’t be using the full travel that you paid for. At .95 and 250 pounds you’ll be using all your travel. Install a zip-tie to check it.
    • Z900 God  ‐    2889
    • #13
    Re: Spring rates
    Reply #13 on: Jun 22, 2022, 04.38 pm
     I get what your saying but I'm totally happy with the front end and as far as I'm concerned the numbers are only a guide. Comparing spring rates without knowing how one another ride or where we ride or what our respective suspension suppliers have done with valving, pre-load, air gap and oil weight isn't going to tell us that much.
    I fiddled about with the back because I always feel it can could be better but the front is untouched and will stay that way and I won't be measuring or twisting anything. No offence meant but I'm blissfully happy with the front and my only regret is working out the average spring rate for the sake of s forum post. :821:
    • Z900 God  ‐    4568
      #14
    Re: Spring rates
    Reply #14 on: Jun 22, 2022, 04.52 pm
    If you’re happy, I’m happy. 🍻
  • Offline HKUSPC40   us
    • Z900 Member  ‐    15
      #15
    Offline HKUSPC40
    • Bike: 2018 Z900
    • Town / City: Everett, WA
    Re: Spring rates
    Reply #15 on: Jul 24, 2022, 06.06 pm
    Check out the spring rates calculator at Race Tech...
    https://racetech.com/VehicleSearch
