Author Suddenly won't start  (Read 8342 times)
    • Z900 God  ‐    4711
      #70
    Re: Suddenly won't start
    Reply #70 on: Jan 22, 2023, 02.28 pm
    *Originally Posted by Smoky [+]
    Haven't had any time last coupla weeks to further diagnose my no start issue.  While I have it apart I'm gonna double check timing then try to start again
    If it starts while priming then your timing is good.
    Something happens once primed or when the ignition is turned on and takes as long to happen as the priming sequence. Something with the throttle plates?
    Has your ecu ever been flashed? (I can’t remember if you discussed this).
  • Offline Smoky   us
    • Z900 Member  ‐    74
    • #71
    Offline Smoky
    • Town / City: E. Tenn
    Reply #71 on: Jan 26, 2023, 11.27 am
    Timing is dead on according to the manual and timing marks.Bike won't hit at all. Not been flashed.
    Last Edit: Jan 26, 2023, 11.28 am by Smoky
    • Z900 God  ‐    4711
      #72
    Reply #72 on: Jan 26, 2023, 01.18 pm
    Just spit-balling here…
    It’s almost as if, after priming, there is no fuel pressure to the injectors or there is fuel pressure but the ecu is not asking them to spray. Or the spark plugs aren’t firing. The problem is definitely electronic in nature.
    Have you confirmed spark AFTER the initial priming sequence has ended?
     To do this you would have to prime/start the engine then with the key still in the "on" position (so as not to initiate another priming sequence), pull a plug and crank the engine to verify you still have spark.
    If you try this you must stuff a rag over the spark plug hole because if there is spark and gas vapor, an explosion could result.
  • Offline GatorZ   us
    • Z900 Pro  ‐    164
      #73
    Offline GatorZ
    • Bike: 2022 S1000r
    • Town / City: NH
    Reply #73 on: Jan 26, 2023, 03.04 pm
    Excuse my ignorance. I haven't read the whole thread.
    But has he tried a scan tool  OBD2 scanner?
  • Offline Smoky   us
    • Z900 Member  ‐    74
    • #74
    Offline Smoky
    Reply #74 on: Feb 09, 2023, 02.18 pm
    No. I have cheapie scan tool haven't tried it. Adapter needed?
    • Z900 God  ‐    4711
      #75
    Reply #75 on: Feb 09, 2023, 02.24 pm
    From what I understand, you do need an adapter. Unfortunately. But the scanner tells you a lot and can clear codes.
  • Offline GatorZ   us
    • Z900 Pro  ‐    164
      #76
    Offline GatorZ
    • Bike: 2022 S1000r
    • Town / City: NH
    Reply #76 on: Feb 09, 2023, 03.38 pm
  • Offline Smoky   us
    • Z900 Member  ‐    74
    • #77
    Offline Smoky
    Reply #77 on: Feb 28, 2023, 01.32 pm
    Looking like head or head gasket
  • Offline Smoky   us
    • Z900 Member  ‐    74
    • #78
    Offline Smoky
    Reply #78 on: Mar 01, 2023, 02.43 am
    Thanks Gator Z
    Ordered it today.
  • Offline Smoky   us
    • Z900 Member  ‐    74
    • #79
    Offline Smoky
    Reply #79 on: Mar 12, 2023, 09.26 pm
    Hey Gator Z or anyone else. I have scan tool adapter now but it won't connect. Mines a '21, I use clear connector on bike? What mode on scan tool? Can't connect....looking for some guidance please
